Results 1 to 10 of 19
Thread: Two speed pump no low speed
    Default Re: Two speed pump no low speed
    I must admit he hasn't yet caught a fish through the ice-fishing hole in his pool!
    Great. You found it. Thx, Ben!
    That Al. What a goof-ball. Wonder how long it will take him to discover this. And, when he does find it, he can tell you what all of it is for. I *think* the smaller bucket filled with rocks goes inside the orange bucket which is then sunk inside a hole he chips in the ice so he can go ice fishing!
    Honesdale PA
    Talk about hijacking a thread.....haha.
    Back on the topic....Carl is right in that the method just tells you of it is shorted, open, or behaving like a cap should. It's actually visually easier with an analog meter, you know the ones with an actual needle as opposed to a digital readout but both work the same way. An ohm meter works by applying a small voltage to the device and measuring the current flow, then calculating resistance.
    Keep us posted on your progress.
    May 2011
    Thanks Al. Wasn't sure if I replied correctly so resending this to you. Sorry if you got it already. Was able to pull and test the capacitor with a multimeter. Didn't measure capacitance so had to use resistance. Discharged the cap, set the meter to 1k ohms and touched the leads. The needle at rest was on the infinity side of the scale, after touching to the cap it quickly pegged towards 0 then returned immediately to infinity. No slow return as i've seen in other guidance on testing caps. Does this indicate failure?
    Was able to disassemble the rear of the motor and observe the following components which i'm not sure if/how they would affect the low speed
    terminal plate where the power comes in - a little dirty but no signs of damage
    some sort of micro switch with a flat metal lead that protrudes towards the motor shaft - tested with the meter for continuity and moved the switch, seems to be ok. What exactly is this switch?
    about a 1" dia klixon thermal protector (I believe) Could this have been damaged and cause low speed to hum? Can it be checked? Anyone know where to find one if I need it?
    Also, as I removed the end cap a plastic collar came out in two pieces which I believe was some sort of collar that was attached to a rotating (centrifugal) switch on the motor shaft. What does this control? Could the broken collar have affected the switch or is it just some sort of dirt/debris collar?
    Lastly, some info on the motor which might be helpful
    Century Magnetek 230V
    2 speed 1.5/.25 HP
    Type CXPM
    Frame 56Y
    Serial BR4-223
    Part 177144
    Encl DP
    ALso have a pic of the end cap which would probably be helpful but didn't know how to attach to reply.
    Thanks again
    send pics to poolforum.pics AT gmail DOT com, and we'll post them.
    -ben
    Honesdale PA
    I would think the cap is OK. Caps either short or open and you're indicating some capacitance. If you use a higher range on the VOM the test current will be lower and you'll see a slower response.
    As for the microswitch and the parts that fell out. My guess is the switch is the starter switch and the thinggy that drives it broke.
    The Klixon is an overtemp switch. Normally closed and opens at high temps. They usually have a temperature stamped on them but maybe not. Should read zero ohms when disconnected. If you don't disconnect it you may be reading resistance of a winding instead. Never had to buy one but Klixon has been around for years and should be a common item if you look in the right place like McMaster or some place like that. I doubt it's bad.
    The centrifugal switch is closed until the motor is up to speed, then opens. It connects a separate winding with the capacitor in series. (usually) The starter circuit gets the rotor turning in the right direction. I'm thinking that if you measure the resistance of the microswitch it will be open. The centrifugal assembly usually makes physical contact with the switch until up to speed then pulls away so there is no friction and wear of the mechanical components when running. This could definitely be your problem.
    On the two speed motors they switch another set of windings in to halve the rotor speed and I'm not sure how all this plays together. Never played with a multi-speed motor. In any case you have to figure out the jizsaw puzzle of broken parts.
    May 2011
    Thanks to all for the assistance. Was able to pull and test the capacitor with a multimeter. Didn't measure capacitance so had to use resistance. Discharged the cap, set the meter to 1k ohms and touched the leads. The needle at rest was on the infinity side of the scale, after touching to the cap it quickly pegged towards 0 then returned immediately to infinity. No slow return as i've seen in other guidance on testing caps. Does this indicate failure? Was able to disassemble the rear of the motor and observe the following components which i'm not sure if/how they would affect the low speed
    Also, as I removed the end cap a plastic collar came out in two pieces which I believe was some sort of collar that was attached to a rotating switch on the motor shaft. What does this control? Could it's failure have affected the switch or is it just some sort of dirt/debris collar?
    2 speed 1.5/.25 HP
    Type CXPM
    Frame 56Y
    Serial BR4-223
    Part 177144
    Encl DP
    ALso have a pic of the end cap which would probably be helpful but didn't know how to attach.
    Thanks again
