Connecting PVC to pool pump
My current pool pump has the pvc threaded into the pump and then glued to all the joints so I can not just unscrew the pipe from the pump. Is there a solution to this when I install the new pump? Thanks and sorry about the stupid question! If I have to, I would like to be able to remove the pump motor and basket with little trouble (i.e. cutting and regluing pvc.
