Results 1 to 10 of 10
Thread: Question about pumps
    Default Re: Question about pumps
    OK.
    Regarding increasing pump size, you need to know that OVERsizing a pump generally causes more problems than UNDERsizing a pump. Oversized pumps push dirt through sand filters, blow out DE filter grids, and collapse cartridge pleats. They generally do NOT increase circulation much -- which is sort of 'set in concrete' by your existing piping -- but they DO increase electrical costs. There are many, many more pools out there that need a SMALLER pump, then need a LARGER one. Please read this PoolSolutions page:
    the-bigger-pool-pump-scam.html
    Do you want to replace just the motor, or the entire pump?
    If the pump body, impeller, & diffuser are in good shape, you can replace ONLY the motor (plus seal and gaskets) using the link from my earlier post. You can replace a 1HP *UP rate* with a 3/4 or 1 HP *FULL rate*, so long as you keep the existing impeller and diffuser. Your existing wiring may determine your choice: the 3/4 HP full rate is a 120V motor; the 1 HP is a 240V motor.
    ALSO: you will have to install a SPDT toggle switch with the 120V motor or a DPDT switch with the 1HP. The problem here is finding an electrician who knows how. Electricians don't even call these switches by their correct names (I just found this out). Instead, they call an SPDT a "3-way" switch and an DPDT a "4-way" switch, naming them for a common usage in household lighting control. Here are example switches
    3 way - SPDT
    4 way - DPDT
    Note that the above switches are power rated, unlike 15A "standard" grade household toggle switches which you do NOT want to use, unless you like replacing switches.
    Let me clear something up for everybody reading this: as a general rule, once your piping and equipment is installed, you can NOT increase water flow, filtration, and circulation effectively by increasing pump size. A big pump with small pipes just wastes electricity. A small pump -- properly selected -- with big pipes can increase flow.
    Ben
    May 2011
    Aberdeen, North Carolina
    I am going to replace everything, get a new body, impeller, diffuser and motor. The piping is 2 1/2" both intake and out. So if I understand, go with the 2 speed 1hp which will replace a 1hp single speed motor and running it on low will be fine? Thanks again, this forum is great!
    mas985's Avatar
    Pleasanton, CA
    I would go with the 1 HP 2 speed SP2607X102S. If the old 1 HP was good enough, then this one should be as well.
    Mark
    Yeah, the 1 hp should be more than good enough. I've got that one for 9 years now.
    "The piping is 2 1/2" both intake and out."
    I assume, OD (outside diameter), which would mean that it's nominally 2" PVC. That's a good size, but the nomenclature will be important when you go to get all the bits and pieces.
    If you REALLY mean 2.5" pipe . . . you are into some really oddball stuff, and should make sure of your replacement fittings BEFORE you cut anything loose.
    Ben
