Re: inward bulging of side walls on rectagular metal frame pool
my old intex kinda got a small waterdrop effect while filling- the bottom edges pushed out as water built up in the pool, making the top diameter slightly smaller than the bottom- if this is what you're talking about, it's normal
Make sure the posts are straight, and the pool is not leaning one way or the other- all sides are sloping inward slightly from bottom to top, not all leaning left/right...
