Thread: What happens when pool chemicals mix.
    Default Re: What happens when pool chemicals mix.
    In a word: Ka-BOOOM!!!!!
    Jun 2011
    I need to ask because I use Cal Hypo with trichlor? I do not mix it together, I dilute the Cal Hypo and add directly to the pool water, never in the trichlor feeder!
    Once it's in the water, chlorine is chlorine, regardless of the source. You just don't want them to come in direct contact with each other.
