Re: New Plaster
during the plaster cure time, I'd follow the installer's recommendations... The CH will come up, but you don't want it to leach out of the plaster to fast (not at all)
I'd use the triclor, and see how much CYA it adds- almost as much as Cl! I think its like 6-8 ppm per 10k gal, so 3-4 for you; if you have 10 pucks left, that should put you at the low end of where you want to be, I think...
Curing your plaster is critical, though, so don't add anything different from what the installer said for the cure period!
