Thread: ph and TA both low
    Default ph and TA both low
    Been doing this for a few years now, but still can't remember - Which do I adjust first? And where can I find the "dosage" for each (borax and baking soda).
    I have 6,000 gallons (give or take).
    The ph is (probably) slightly below 6.8 (the test kit I have only goes that low) and the TA is at 50 ppm.
    Thanks!!
    Default Re: ph and TA both low
    Since your pH is at the lowest your kit will register, it's a good bet that it's actually a lot lower. I would start with about 2-3 cups of borax added very slowly through the skimmer with the pump running, give it 2-3 hours to circulate, then retest and add more as needed to get the pH up above 7.0. Depending on how low your pH actually is, it can take large amounts of Borax!!
    Your TA might move slightly, or might not move at all--but the pH is the more critical of the problems right now, so fix that first, then deal with TA.
