Re: Fighting the Mean Green
Congratulations on the clear pool--ain't it great??
I wouldn't worry about the polyquat--some of us never use it, some of us only use it for winterizing, or if you're dealing with metals in the pool. If none of those things apply, then just know that adequate chlorine levels will keep the algae away. With your CYA of 65, you want to keep your chlorine between 5 and 10 ppm at all times. If you need to shock it, shock it to 20 ppm until it clears again and you're not losing any chlorine overnight. There's nothing else you need to add on a daily basis, other than bleach. In a 22K gallon pool, each 3 quarts of 6% bleach will raise your FC by approximately 2 ppm, so you can use that as a guide when adding your daily bleach dose.
Your CYA may lower slightly over the summer, depending on how much you backwash the filter, and how much splashout you have, but that's the only way it will come down. I wouldn't bother testing it more than once a month unless you're adding more CYA via dichlor or trichlor, which I wouldn't do for your pool. It's fine where it is.
Take 5 minutes a day, test chlorine and adjust it as needed, test for pH once a week or so, and you should be good to go through the summer!!
