Don, if you've been happy with the sand filter, keep it. Sand filters do a great job and are the easiest to use and NOT screw-up. As I pointed out in the 'cross link'; 50 lbs of pea gravel is a good thing (and was backed up by the other posters). If you are worried about something else 'failing', replace any latterals that are 'suspect' and even the hub they attach to, it'll cost you $$$ less than changing the entire filter.Originally Posted by dbursch
Whatever you decide to do - Good Luck, and have a great pool season!! This forum is a pool owner's best source for having a hastle-free pool season, should anything else arise, post, and the nice folks here will help you![]()
