Thread: hayward filter
    Sue225 is offline Subscriber Thread Analyst Sue225 0
    Jun 2010
    NW Indiana
    Default hayward filter
    I have a question. Why are we not getting any flow from return to pool. Backwash works fine there is definitely not a problem with pump as when we take off the hose from filter and turn on the pump the water pumps very well through the hose. Filter was bought in august last summer was used for 1 month before we closed the pool. The pressure valve looks like it is crooked. we cannot get a pressure reading from it or there is no pressure. Sand is from last summer. Any ideas??
    We need to get chlorine in the pool ASAP finished filling last night. Could i dilute bleach and throw in the pool? Appreciate your feedback
    Default Re: hayward filter
    Sounds like you have a broken pressure gauge, can you feel water coming through the return when the pump is running? If yes, it's just a bad gauge.
    Jun 2010
    NW Indiana
    No I can feel no pressure in the returnwhen the pump is running. Water is not returning to pool!
    madwil is offline Registered+ Widget Weaver madwil 0
    Apr 2011
    virginia
    sounds like a clog or stuck valve...
    Is there possibly a valve on the return side that is closed? Or a plug in the return that wasn't removed on opening the pool? (I'm assuming that this is an AG pool)
    Jun 2010
    NW Indiana
    Could you believe that the people who replaced our liner connected all the equipment and they left the winterizing plug in the eye? Problem solved!
    Thumbs up Re: hayward filter
    Well, of course I believe that
    I'm glad it was something quick and easy and that you now have an operational pool!
