Thread: Backwash while pump is on
    May 2010
    107 Baldwin Terrace
    Default Re: Backwash while pump is on
    AL!!!! You are a GOD SEND! That's all it was
    ROCK ON! Thanks so very much for your help!!!
    Honesdale PA
    I wonder how many new pumps are sold to solve these relatively simple problems.
    Glad I could help.
    BTW: About the only thing that could happen when changing valve positions while the pump is running is to lift the spider gasket out of its channel in the valve assembly. Then you will have leak paths between ports that should be isolated. Solution....new gasket.
