Thread: Pool light problem
    May 2011
    St Thomas, USVI
    Default Pool light problem
    Purchased house with pool, first time pool owner, the light fixture was floating in socket. There is water in the fixture, no outer ring to keep fixture in socket. Light does not work and can not get the fixture out of water to look at or test because I can not get the cord to feed out of the socket. Yes the power is turned of at breaker. I have found what I think is the junction box and there is two to three feet of excess power cable to feed into the conduit running towards the fixture. Problem is, all under concrete, in ground pool.
    Default Re: Pool light problem
    I'm on my way out, so I can't answer, but I want to work others to note your location. (Virgin Islands) Otherwise, they are likely to assume you are on the mainland, and have access to everything here.
    It would probably help if you take some pictures, and send them to poolforum.pics AT gmail DOT com. I think I know what you are describing, but I'm not certain.
    Ben
  1. CFL Pool Light Conversion & can't seal American Products Pool Light
    By DrBAF in forum Pool Equipment & Operations
    Last Post: 09-11-2012, 11:09 PM
  2. Inground Pool light fixture problem
    By morronatico in forum In-Ground Pool Construction and Repair
    Last Post: 06-15-2011, 07:59 PM
  3. pilot light won't light on pool heater
    By packerfan in forum Pool Equipment & Operations
    Last Post: 06-12-2010, 03:10 AM
  4. Pool light problem
    By derrikm in forum Pool Equipment & Operations
    Last Post: 07-27-2006, 02:40 PM
  5. Pool light out
    By KirstenHW in forum Pool Equipment & Operations
    Last Post: 06-22-2006, 03:48 PM
