Thread: drainage around AGP
    Apr 2011
    connecticut
    Default drainage around AGP
    I would like to install a french drain around 3/4 of my round pool before the pool is installed because of draininge concerns. Will digging a 1-2 ft trench around the pool weaken the pool foundation and possibly lead to future leveling issues? How far away from the pool would I need to dig the trench?
    Apr 2011
    connecticut
    Default Re: drainage around AGP
    To the top.
    Apr 2011
    connecticut
    IHelp! s it safe to dig 12-18" around the perimeter of an AGP? I'm almost ready to install.
    Apr 2011
    virginia
    you should be fine, temporarily while doing the french drain- I wouldn't leave a trench for long without takinig some measure to prevent erosion from beneath the pool
    As always, make sure you know where any buried pipes/utilities are!
  1. drainage for AGP (with pics)
    By link6 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-01-2011, 09:13 AM
  2. Pool Drainage question
    By vegasmclaws in forum Pool Equipment & Operations
    Last Post: 05-29-2011, 11:58 PM
  3. How long should drainage hose be?
    By west1745 in forum In-Ground Pool Construction and Repair
    Last Post: 07-25-2006, 08:30 AM
  4. Above ground pool drainage....
    By rrivera62 in forum Above-Ground Pool Construction & Repair
    Last Post: 03-29-2006, 12:49 PM
