OK. We especially need to know the CYA reading. Is that what you used for your source of chlorine last year as well? If so, it may be that your CYA level could be really high which in turn would require you to shock to a pretty high level in order to kill the algae. For a 30K pool, what does the dichlor package say that 3 lbs. will take the chlorine level up to?
