Thread: Building new pool need advice
    May 2011
    Mesa, AZ
    Default Building new pool need advice
    I am building a new diving pool in Arizona, doing it as owner builder, and just want to make sure I'm making some good decisions. I plan on cleaning it myself, and prefer simplicity in order to reduce risk of problems. Here's what I got so far:
    SWG system
    Cartridge filter
    The Pool Cleaner water sucking cleaner
    We will have a small water feature with the pool as well. Possibly using a 2nd pump.
    Default Re: Building new pool need advice
    Three observations:
    1) In AZ, you'll lose a LOT of water to evaporation. I'd strongly suggest running the fountain with a dedicated pump on a time clock. Even here in TN, a fountain 'costs' a lot of water, but nothing it will in AZ. With a time clock, you can operate it only when someone is watching . . . and save water, electricity and pool chemistry problems.
    2) In terms of water usage, cartridge filters use the least and sand filters use the most.
    3) I believe the common pattern out your way is a 1spd pump with a time clock. If you are going to use an SWCG (salt water chlorine generator), you'd be better off with a 2 speed pump running on low most of the time. That way, your SWCG can run all the time, instead of just when the pump is on.
    Ben
