Re: chlorine levels
Ok. Got it.
Went ahead and purchased walmart clorox. Threw 4 gallons of it last night. This morning the pool floor looked better than it has looked in a long time. Seems like it worked. Also back washed and added de before throwing clorox in. Been vaccuming all day. Will throw in other 2 or 4 gallons of clorox and run pump all night again.
Tried shot glass cl measurement and according to readings my cl was 20 ppm last night before throwing in clorox. Also tested water this morning and was told my cl was high, which I knew and also ph. Said cya was fine at 30?
Weird. Seems I had the adequate cl and cya to get rid of this stuff but I guess water preferred clorox rather than granular chlorine I was using..? Hopefully I can get rid of this stuff completely within next couple days with clorox. Also went ahead and got some liq chlorine from les lies. Wl be using this stuff until algae is totally gone. I will also plan on changing sand filter. You think this may be necessary? Thanks for the great advice everyone.
