Re: chlorine levels
i had a pool tech come out to look at my pool for free. specializes in pool construction and has a pool supply store.
he said that brown dust is a result of previuos owners covering up the pool surface with "epoxy" paint to make it look decent when selling the home. he said this is not algae i'm dealing with.
this was his prognosis:
the epoxy paint is coming off in some places and getting very thin in other areas. due to the thinning and wearing of the epoxy, the plaster beginning to be exposed; aso understand that plaster has sandmix in it.
so the brownish looking dust and brown spots (pool floor does have several small brown spots in different areas) are due to sand that is mixed with the plaster, especially where the plaster is very thin.
how does this sound? kind of makes sense to me.
my question/s then:
if not algae, why when i poured clorox pool floor cleared up quite a bit? i will note that i was having no success with granular chlorine.
his explanation was that there must of been some sort of reaction that bleach caused on this plaster/sandmix or that granular chlorine coupled with other water chemicals did not have the same affect that pure bleach coupled with other water chemicals balances had on the pool floor, or something to that effect.
so basically then, the coat that covers the pool surface is wearing thin and therefore plaster, sandmix, cement, etc... are being exposed and thus when i brush i will always be brushing exposed areas and will always have this brown stuff pick up whenever i brush. so to solve the problem, i need to repaint, or replaster...
just wanted to share and ask for yoour oppinions, thoughts. what do you all think. thanks
