Hayward Navigator slow... already replaced some parts
I have a Hayward Navigator which is moving slowly. I've replaced the rubber feet, the wings and the flaps, however the pods are pretty well worn down. I didn't think that those would really slow the movement, but I wanted to check with someone who knows what they're doing before I buy anything else. I recently had to replace the board in my pools control panel, and the pool guy replaced some parts inside the vacuum, he said he replaced some bearings and a couple other parts. Either way, I'm already down $750 and would like to minimize any more cost if I can.
There seems to be good suction, the feet are moving, turbine is spinning, but normally with the way my valves are now, this thing should be climbing the walls.
Any advice would be appreciated!
