Results 1 to 10 of 12
Thread: High Ph a problem?
    Condo Steve Guest
    Default Re: High Ph a problem?
    Thanks,
    No scaling noted. I'll continue till I get a measurable phenol score or Ben's kit arrives.
    Condo Steve
    If you have a salt chlorine generator, then you don't really have to worry about adding too much acid, because Ph will go up and may be why you can't get it down very easily. If not, then ignore this comment.
    Another thing you can do is to use the acid demand drops if you have them and see how far you are above 8.2. After you do your test, add them one at a time until the water changes to something immediately below pink. Then do the same thing the next day. Hopefully it will take fewer drops each day to turn the water. If not, then you may need to be adding more acid each day to get you there since you are not making any progress.
    I just found this on google -- an old post on poolforum. It may be the easiest thing to do to get your pH correct. Sorry, but I don't know who posted it since the cached version isn't very easy to read. Note that you have to adjust for the size of the pool.
    Here's what I started doing. Its pretty accurate.
    I take a one gallon sample of pool water. Then I add one drop of 20% muriatic acid, mix and run pH. I repeat until the pH is what I want. For every one drop of acid I added to get the pH right, I add a quart of 20% muriatic acid. This is for a 20,000 gallon pool.
    Here's the calc:
    Fact: 20 drops = 1 milliter
    Fact: 3785 milliters = 1 gallon
    (#drops added X 20,000 gal)/20 drops per milliter)/3785 milliters per gallon = Gallons of acid to add to pool.
    Example: (1 drop of acid X 20,000 gal)/20/3785 = .26 gallons acid
    Condo Steve Guest
    Hoostat,
    That's a gem. I keep waiting for the kit to arrive so I can just measure my real Ph and do a calculation on BleachCalc for acid dosing. Watched pot never boils.
    I'll give it till Friday, then I'm in on the gallon-o-pool-water method.
    Thanks a bunch for the replies. I almost look like I know what I'm doing poolside.
    Condo Steve
