Thread: Is my salt level too high? Test vs. digital readout.
    Default Re: Is my salt level too high? Test vs. digital readout.
    Two possible answers:
    1) It's doubtful that the difference between 2900 and 3600 (25%) is critical. Few things in the pool industry are that exact.
    2) Call AquaRite tech support, and then try to break through to a level 2 tech (not the first person who answers). Ideally, you want someone who helped write the manual, rather than one of the guys who's flipping to the right section, and then reading the answer to you. Ask them about calibrating your unit's read out.
    Ben
    May 2010
    Thanks! I hadn't thought of that, but will do next week. Loving the SWCG so far. Would never have come this far with my pool without everyone's help here.
    Tabitha
    May 2010
    As a general rule, I go by the unit itself. I have taken water samples to multiple pool stores only to find out that they ALL vary. Test strips are usually a waste, while the battery powered testers seem to be the most accurate. I did manage to find two different pool stores that came up with the same reading, so that is what I went with. My low salt light went out and the High salt light never came on, and I've got good chlorine. My particular preference is to keep the salt level on the low end to avoid the salty taste. I think I have seen the battery operated Salinity testers on the internet for under $15. I may just break down and buy one to avoid the pool store guys.
