Watermom
Well, the good news is that you found us and we can help you get this cleared up.
A couple of questions:
-- Do you have a good test kit? If not, you need one and the one we recommend is the Taylor K-2006 or the 2006C which you can order from Amazon from the link in my signature line. Well worth the money.
-- What kind of filter do you have?
I would suggest not using the cal-hypo. Your calcium hardness reading is already pretty high and vinyl pools do not need calcium. When the level gets too high it can cause cloudy water problems. For the time being, I'm going to suggest that you use something other than bleach --- dichlor shock powder -- for three reasons. One, it will be convenient to shock with and with a large volume pool that is green, it is going to take a lot of bleach bottles. Two, it will add stabilizer (cya) to your pool which you need. Three, it will help to lower your pH. You will not want to use it all summer, however, or else your cya level will get too high. Use it for awhile and monitor your pH and your cya level. I'd aim for around 35-40ppm of cya and then switch over to using bleach.
Test your pool a minimum of twice a day and 3 or more times per day is even better and each time, shock it back up to about 12 or so. The key to killing algae is to sustain the high cl reading without letting it yo-yo up and down. Also, run your pump 24/7 right now while you are working to clear this mess.
Read through many of the posts on the forum and also on our sister site, poolsolutions.com where there is lots of good info that you will benefit from. Keep us posted of your progress and come back with further questions. Stay out of the pool store!!!!!! (except to maybe buy some dichlor)
Welcome to the forum!
