Poconos
Only two choices, keep cleaning the skimmer socks and do quick backwashes. By quick I mean to backwash for maybe 30 seconds or so just to flush the bulk of what was caught. Don't attempt to get the filter perfectly clean as you would in normal operation. The second option is to let the crud settle then vacuum to waste but this uses a lot of water and it takes time for the fine particles to settle. Cleaning the skimmer socks is the easiest and obviously doesn't use additional water.
Al.
