Thread: all 4 pool return ports are plugged
    May 2011
    tucson, arizona
    Default all 4 pool return ports are plugged
    hi folks:
    i have a combination spa and pool setup--the spa has a channel into the pool and both run off the same pump/d.e.filter: there are 2 return lines. 1 line feeds the spa and one line feeds the pool--i think; the pool has 4 return ports, 2 on each side--they blow a little air but thats it. i used a 1/2" socket & extension on the spa fittings and easily removed and cleaned them but this wont work on the pool fixtures--any ideas on getting these out? its a big, old pool (14' x 62') and the ports are about a 12" under water. any experience you could share would be much appreciated and thanks/ craig
  1. Plugged up pipes - how to clear?
    By jadedreams in forum Pool Equipment & Operations
    Last Post: 06-06-2007, 11:13 AM
  2. Adding a return to an AG pool.
    By esalkin in forum In-Ground Pool Construction and Repair
    Last Post: 08-16-2006, 09:39 PM
  3. How far from pool do return lines go?
    By kissinger99 in forum Pool Equipment & Operations
    Last Post: 08-10-2006, 05:05 PM
  4. DE in pool return
    By Xndman in forum Above-Ground Pool Construction & Repair
    Last Post: 07-20-2006, 05:22 PM
