Thread: CYA at opening
    May 2010
    Central NJ
    Default CYA at opening
    Hey all! Nice to be back!
    OK, I just want to put out there an observation over a few years of pool openings. Maybe I am just crazy, but my CYA levels always go from nearly nothing to a little and up gradually until they are accurate after about, I don't know, a week maybe less? This is without adding anything containing CYA btw. I NEVER adjust for CYA until I get a consistent reading over three tests in as many or more days. Just putting that out there for who want to get right on that low or zero reading. My pool doesn't behave like there is no CYA btw, it holds militantly on to the chlorine (I run about 85). the way I open we are not getting in it for a week at the earliest anyway, that's why I like to open kind of early. And the cold pool isn't growing stuff. I was blue again this year, opened yesterday, vac today and looks near perfect. Crazy shock though! Anyone got a 30yd dumpster load of whites?
    33,000ish gallon, 20X40 IG Vinyl Liner, no heater. Full sun, Sand filter. Been pool stored more times than I can count, not anymore! Thanks PF!
    20'x40' rectangle 33K gal IG pool; Bleach; Hayward sand filter; AO Smith 1HP pump; 14hrs; Taylor K2006; utility water; summer: ; winter: ; iPhone; PF:3.6
    Default Re: CYA at opening
    Lol, glad to see you back this season. I have no explanation for why your CYA numberscreact the way they do-- it will be interesting to see if others share your experience.
    This is just a guess, but if your water temperature is colder upon opening, then if you do the CYA test and don't warm up the water first it will take longer to react to form a precipitate so will read artificially low. If your pool then warms up after opening, your warmer pool water would have a more accurate CYA test. In general, you want to have the test sample at least up to room temperature when doing the CYA test. Or you can just wait longer than 30 seconds for the mixing, though I don't know how long to wait -- maybe double the time for every 10ºF below 70ºF though that's just a guess (so that would be 2 minutes if the water is 50ºF).
    May 2010
    Central NJ
    Temperature could certainly explain this. I open my pool on the early side and have been timing the weather pretty well (getting dumb lucky) the last few years and hitting an early warm spell soon after opening. I considered the notion for a brief instant that CYA might be heavy and thus wallowing in the hopper until fully mixed, but the bottom drain was a nagging source of doubt, then came my Graduate School Dean, a chemist, who said CYA is no different in suspension than milk in your coffee.
  1. Help with opening up a !0,100 gal AGP
    By yardbird in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-27-2012, 10:00 PM
  2. Will I need vac for opening?
    By poolbee in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-21-2007, 02:04 PM
  3. Low pH upon opening
    By kacy in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-11-2006, 10:14 AM
  4. Opening Day
    By TwistyKat in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-06-2006, 08:46 AM
  5. When to let Cl come down after opening
    By Davenj in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-19-2006, 02:54 PM
