Thread: How often to do each test?
    cnk is offline ** No working email address ** cnk 0
    Default How often to do each test?
    I just got Ben's kit. This is our first year using chlorine. Could someone please tell me how often to do each test. Also, what numbers am I shooting for on each test? I already tested the CYA and it was 30. Is this appropriate?
    Default Re: How often to do each test?
    Test chlorine and ph every day or at least every other day. Every couple of weeks is probably ok for alk and cal. CYA a couple of times a season is plenty. CYA of 30 is fine.
    Good readings:
    PH 7.4-7.6 (but anywhere 7.2-7.8 is acceptable)
    Alk 80-125 (although if it is a little higher, no problem)
    FC 3-6 (for a cya reading of 30)
    CC zero (FC + CC = TC)
    Calcium hardness 200-400 (but not needed in vinyl pools)
    CYA 30-50
  1. pool test strips vs dropper test kit
    By sputterbug10 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-22-2012, 11:23 PM
  2. CYA level-my test and pool store test
    By hancop in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-20-2006, 07:13 PM
  3. Test results vary between meter and drop test - not sure what to do?
    By west1745 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-29-2006, 04:27 PM
  4. Necessity for ordering Salt Test in PS234 test kit
    By Scarlett in forum DPD-FAS based testing
    Last Post: 06-13-2006, 01:04 AM
  5. PS233 test kit and CYA test question
    By mshumack in forum DPD-FAS based testing
    Last Post: 06-06-2006, 11:28 PM
