Page 4 of 5 FirstFirst ... 2 3 4 5 LastLast
Results 31 to 40 of 50
Thread: Help! I'm ready to pull my hair out!
  1. #31
    Default Re: Help! I'm ready to pull my hair out!
    Actually Borax and pH Up are not the same thing. Janet mis-spoke. pH Up and Washing Soda are the same thing.
    l
    My point was that the end result would be the same, for all intents and purposes.
    May 2011
    Indiana
    I checked my numbers this morning:
    pH 7.2
    Chl 12 using the shot glass method.
    The pool is clearer, I can see the skimmer pole on the bottom of the pool. How often do I test? The sun hasn't hit the pool yet this morning. We did get a bunch of rain last night.
  3. #33
    Apr 2011
    virginia
    the more consistently you can test and maintain the FC, the quicker you'll get past the cloud... every hour is often enough, but 2 times a day is fine if that's all you can do- it'll just take a bit longer to reach the end!
  4. #34
    We generally suggest 3x/day--morning, mid-day sometime, and after sunset. More often than that doesn't hurt but if you want any hope of progress you need a minimum of 2x/day.
    May 2011
    Indiana
    The green is gone!! The pool is a little cloudy but no longer green. My pH is between 7.2 and 7.5 and my chlorine is about 12 (shot glass method). What should I do now?
  6. #36
    Apr 2011
    virginia
    your CL was 12 yesterday, and still 12- did you add anything?
    you should maintain the CL at shock level until
    1- FC holds overnight (<1 ppm difference between sunset and sunrise without adding anything)
    2- CC is <.5
    3- water clear (some people cut short on this one, but recommend keep it to oxidize the cloud()
  7. #37
    May 2011
    Indiana
    I did a test around 12:30pm yesterday and my pH looked to be about 7.0 so I added 1/4 box of borax. I checked the chlorine around 4pm and it looked about 9 (shotglass method) so I added one gal of 10%. I haven't added anything else since then.
  8. #38
    Sounds good. How's the water looking?
    May 2011
    Indiana
    The green is gone. I need to vacuum again to get what I missed on the bottom of the pool. The water is a bit cloudy, but I can see the bottom.
  10. #40
    On the right track!
  1. Scrutinize my cart before I pull the trigger???
    By Shawdaddy1972 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-06-2012, 03:44 PM
  2. Help...about to pull my hair out or tear down the pool!!!
    By butterfly26_78382 in forum Pool Chemicals & Pool Water Problems
    Last Post: 09-06-2011, 04:11 PM
  3. SC-60: How to pull the power cord
    By CAL7 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-29-2011, 08:12 PM
  4. Won't pull water in when backwashing
    By adamsmom1 in forum Pool Equipment & Operations
    Last Post: 05-07-2008, 06:58 PM
  5. need to get pump to pull from bottom
    By bkny1055 in forum Pool Equipment & Operations
    Last Post: 08-06-2006, 01:49 PM
