Re: Pump leak
Jason,
I'm no expert on this, but I had a similar problem with my hayward super pump 2 years ago. It sounds like the main seal is going, which is not uncommon. It is not a hard fix. I was able to find an exploded view of my pump (at the hayward site) online. I think the cost was about $10-20 and took about 40 minutes.
What I can tell you is DON'T LET THIS GO!!!! Get it replaced ASAP, or you probably will end up smoking the bearing in the motor. (Don't ask me how I know this).
Like I said, I'm no expert, just throwing my 2 cents into the pot.
Good luck
Ted (TRHOD) North Canton, Ohio
1974 Anthony 24,000 gal IG vinyl, Hayward sand filter/1hp superpump. (5) 2x20ft sungrabber solar panel roof mounted
Acquired pool June 2006 Been BBBing ever since
