Thread: Correct Pump Size for Filter
    May 2010
    Illinois
    Default Correct Pump Size for Filter
    Happy spring folks,
    I've always wondered if my pump is the right size for my filter. The problem is that I don't understand "dynamic head".
    I've got a Tagelus TA-50D sand filter. It's rated at 50gpm.
    My pump is a Sta-Rite P6E6E 1hp
    The pool is about 25 - 30 (or so) feet from the pump, but I've got the option of running a solar panel heater that's about 20' above pump level on the roof. The pump is about 2 feet below skimmer level & even w/ the return.
    If it matters, my pool is about 13' x 24'
    5 ft deep in the deep and and 3 ft deep in the shallow end (split pretty 50/50.
    I'm thinking (from the curves on the Pentair page) that my pump is oversized. If I'm right, short of buying a new pump, is there something that I should do to help the situation? I've seen sand in my backwash.
    Thanks!
    -Rob
    May 2010
    Illinois
    Default Re: Correct Pump Size for Filter
    Sorry - couldn't figure out how to edit my last post...
    I wanted to add that the pipes for my pool are 1.5"
    Rob
