Results 11 to 14 of 14
Thread: Pump and filter sizing
    Apr 2011
    virginia
    Default Re: Pump and filter sizing
    bigger filter means less cleaning- 36 is probably enough for 10k gallons, but 48 would give you an extra 1/3 time between clean/refill, pretty much...
    even with the bigger filter, I'd down size the pump- and consider a 2 speed run on low for filtering, only high for water fountains/etc and vacuuming-
    on low, consumes like 1/4 power but 1/2 water flow, so on low 2 hours filters as well (sometimes even better) than high for 1 hour, but less total power used to get it there!
    May 2011
    Ok thank you. I think I'll stick with the 36. And a two speed 1 HP will save electricity and pay for itself eventually.
    mas985's Avatar
    Pleasanton, CA
    Quote Originally Posted by wsommariva View Post
    Hi everyone,
    Just want to make sure that I have adequate sized equipment.
    10,000 gal fiberglass. 1.5 hp pump and 36 sq ft PE filter.
    Other considerations for pump size would be if you also have a spa, water feature or anything else that might need higher flow rates. If not, then I agree with everyone else that you can go with the smallest pump possible.
    Mark
    May 2011
    I'm hoping that a new pump will help eliminate my cloudy water problems. I've tried many things.
    Thanks everyone.
  1. Question about Pump/Sand Filter Sizing
    By NTL1991 in forum Pool Equipment & Operations
    Last Post: 08-11-2012, 11:39 PM
  2. Pool Filter & Pump Sizing Question?
    By zooba72 in forum Pool Equipment & Operations
    Last Post: 06-17-2012, 11:02 PM
  3. Pump/Filter Sizing Mytery
    By kingbud in forum Pool Equipment & Operations
    Last Post: 10-06-2008, 01:03 PM
  4. Pump sizing for filter
    By derrikm in forum Pool Equipment & Operations
    Last Post: 09-18-2006, 08:05 PM
