Results 1 to 10 of 40
Thread: Steps - Switching from Baquacil to Chlorine
    May 2011
    Middle TN
    Question Steps - Switching from Baquacil to Chlorine
    Like so many others I’m used Baquacil (for 2 seasons at our house here in middle TN) and I’m ready to switch to chlorine – as part of ‘pool start-up’ for this season. However, I do have a few questions in order to move forward in the process – and after reading several of the postings on this forum (and some others as well), all of which have been very informative to me personally (I’m not a long term pool owner)!
    We have an in-ground pool of ~ 20,000 gallons in size (with the cover still on due to rainy & cold spring weather) and the test results from the local pool supply / builder (as of today May 20th) is as follows:
    Baq. = 0, pH = 7.08, Alk = 1, Shock = 3, and a water temp. of 62 degrees.
    Additionally, as of this p.m., I’ve purchased a Taylor 2006 tester in order to better monitor the change over to chlorine – and hopefully on to a chlorinator system at a later date. But…first things 1st, I’d like some recommendations with the steps in order to open / start-up the pool using chlorine – given that the cover is still on the pool, no pump / water circulation thus far, and looking kind of scummy on the bottom & sides?
    With the current Baq. level at (or near) zero, and the pH at 7.08, my best guess is that 1st - I need to clean and vacuum the pool utilizing the sand filter, 2nd – change the sand within the filter, 3rd – add some amount of stabilizer, 4th - start adding chlorine (in the form of bleach) in order to obtain a FC level of ~ 1ppm, - all the while making checking / making sure the pH level is maintained ~7.0 (or slighter higher), followed by raising the Alk level (based on the type of chlorine to be used long term).
    But, like I said prior, this is only my best guess – so any and all inputs would be welcomed!
    Gene
    Default Re: Steps - Switching from Baquacil to Chlorine
    The guide at the following link outlines the procedure for converting. You made a good decision to buy a good test kit. That is going to make the process much easier! Keep us posted how things are going and let us know if you have additional questions. Read some of the other posts in the Baquacil section of the forum (or Baquagoop as we like to call it) and also take some pictures to document the conversion. You are going to be so glad you converted once the process is finished!
    Welcome to the Pool Forum!
    http://www.poolsolutions.com/gd/conv...-chlorine.html
    May 2011
    Middle TN
    Watermom,
    Thank you for your response! I have read many of the guides, and have printed a few so as to add my notes, but I do need to read some in the Baquacil section. Taking some pictures is a very good idea and I will keep you posted. Did you have any comments / concerns with regard to the steps I was suggesting?
    GeneNTN
    I wouldn't bother with cleaning the pool yet and especially not changing the sand. I'd just start adding bleach. You say that your Baq. level is at zero or close, but you may find out that you do still have a little more in there than you think. When you add the bleach, you'll find out. It may turn some funky shades of green. After you are able to hold a chlorine level overnight and the pool water remains clear, then is the time to change out the sand. Wait to vac until you see if your pool does turn green. No sense in wasting water. Keep us posted with progress.
    Apr 2011
    virginia
    second what watermom said- don't change your sand until after you get a clear pool, the residual baquacil can cause you to have to change again!
    Yeah, you'll need to change the sand when it's all done, no choice in the matter, but it's a total waste of time and money to do it before.
    Filter Sand is usually pretty cheap. A lot of the stores in my area regularly put it on sale for $5-$7 per 50lbs.
