Results 1 to 4 of 4
Thread: cloudy water
    May 2011
    NJ
    Default cloudy water
    cl. is very high PH 7.6 using a sand filter and pool is still cloudy after 9 days of filtering, any sugestion on what to do next?
    Default Re: cloudy water
    We really are going to need some current water testing results taken with a drops-based kit to be able to help. Also, tell us what type and volume the pool is and what all you have added -- meaning ingredients and not just "shock." Then somebody here can try and help.
    Hi Dave;
    When I upgraded your registration, I noted your email address. It sounds like your pool might be a commercial pool? If so, you'll need to include all the following info:
    + Approx daily bather load
    + Pool gallons
    + Pump size
    + Chemicals (kinds, & approx quantities) added in the last 2 weeks.
    + Test results.
    Clearing up a commercial pool is not like clearing up a lightly loaded residential pool.
    Ben / PoolDoc
    (Admin)
    Also, is the cloud is clearly white, that's different then if the cloud is green. It changes how you treat it.
  1. Cloudy Water
    By PoolConfusion in forum Dealing with Algae & Slime
    Last Post: 07-23-2012, 08:51 PM
  2. Cloudy Water
    By joserq in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-09-2012, 01:01 PM
  3. Cloudy Water
    By ComeShareACupofTea in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-06-2011, 11:49 PM
  4. CLoudy Water
    By Sunshine427 in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-01-2008, 03:57 PM
  5. Cloudy Water & Water Behind Liner
    By cschnurr in forum Dealing with Algae & Slime
    Last Post: 09-19-2007, 09:04 PM
