Thread: Stabilizer
    Apr 2011
    Default Stabilizer
    I didn't see in the BBB method what we use for stabilizer. Does this have to be bought from the pool store?
    It's the stablilizer that adjusts the cya....yes?
    Sorry I can get very confused....easily (
    Cooper
    Default Re: Stabilizer
    You either have to use a stabilized form or chlorine such as trichlor tabs or dichlor shock powder. If you use liquid chlorine (bleach) which we recommend for most pools, then you have to add the CYA separately. It is sometimes labeled as stabilizer or conditioner. Check the label ingredients. If it says cyanuric acid or isocyanuric acid, it is the right stuff. Sometimes you can find it other places besides a pool store like maybe Walmart. I usually just get it from the pool store.
    Apr 2011
    Thanks watermom! I found some last night and put it in with a sock at the outlet. I still can't get a level this morning but I've seen where you say it takes a few days to get in there.
    Cooper
    Don't worry--it can take 48 hours to a week to get a reading. Don't rush it. You can ALWAYS add more CYA, but if your level is higher than you want, it's a pain to lower it.
    As long as you keep checking and adjusting your chlorine, your CYA will slowly increase and you'll see your chlorine levels stabilize.
    Apr 2011
    Thank you Carl!
    Cooper
    Mar 2011
    I didn't put mine in a sock. I just poured it in slowly and over a 4 hour time period. Did I screw it up?
    No, that is fine. I always put mine in through the skimmer. You'll need to keep your pump running 24/7 for the next 4 or 5 days and don't backwash or you'll just throw the CYA out. It is slow-dissolving so don't test for it for about a week.
    EDIT --- After re-reading I wasn't sure; when you say that you just poured it in slowly, you did mean that you poured it into the skimmer, right?
  1. Is stabilizer necessary?
    By JimK in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-29-2012, 07:48 PM
  2. Stabilizer
    By Sue225 in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-12-2011, 01:22 AM
  3. Stabilizer
    By Calcutta in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 03-26-2008, 11:31 PM
  4. Stabilizer
    By mackeeg in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-17-2007, 01:16 PM
  5. HTH Stabilizer
    By let_her_flicker in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-20-2006, 07:57 AM
