Re: Opening my Pool the right way need advice
Hi Vicki,
At most, opening your pool should be tedious, not painful and certainly not a nightmare. I opened this year to jello green slime and in 48 hours it was mostly clear. A week later, it was crystal clear. Here's how I do it, or suggest.
1) Add water until your level is sufficient for the skimmer to work.
2) Connect your pump and filter and turn it on.
3) Test your water and find out what your levels are. Mostly you need to know your
FC (free chlorine), your CC (combined chloramines) or TC (total chlorine) (TC = FC + CC) It's probably 0
pH (I'm of the opinion this is most important). If it's high, low or good, you need to know.
CYA/Stabilizer level. This is PROBABLY 0 as well, but if it's not you need to know what it is.
4) At this point, what I did was add 4 gallons of 12.5% liquid chlorine. I wouldn't NECESSARILY recommend that (my pool is about 19k) because it probably will lighten your liner. Since my liner is old and ugly, I don't care. However, if you have 0 CYA, I'd start by adding 3 gallons of 6% bleach. That will add 10ppm of FC to your pool. If you want to add a 4th, I'd go for it, because it will probably be metabolized very quickly.
5) Start vacuuming your pool to waste. If you have a return-side, or self-powered clearer, run it. If you vacuum or have a suction-side cleaner you'll want to vacuum to waste.
6) If your pool is green, check your FC level and add chlorine 3 x a day. 1 gallon of 6% bleach adds 3 1/3 ppm to 18,000 gallons. Aim for 10 to 12 ppm (assuming CYA=0).
7) If your CYA level is above 0, check Ben's Best Guess chart for the appropriate Shock level of Chlorine for that CYA level (for example, CYA of 30 to 50 means shock to 15ppm).
8) Patience and Persistence are the key.
