Guess what???? I have REAL numbers!! I took off work 2 hours early, and drove about 35 miles to get accurate tests... I was desperate. Here goes:
saturation index: -1.11
total dissolved solids: 100
free chlorine: 4.0
total chlorine: 4.0
combined chlorine: 0.0
ph: 7.1
cya: 8
copper: 0
iron: 0
total alk: 0
adjusted total alk: 0
calcium hardness: 0
temperature: 75
baq sanitizer: 0
baq shock: 51
Yeah I know, the shock is probably my main problem!!
O.K., So this lady freaked when I told her I was putting bleach in pool. She said it will ruin plastic components, & is not good for skin or eyes. She said that this is what I would have to do.
1. don't add anything for 5 days.
2. change sand Saturday.
3. run pump constantly.
4. test water Monday & call her with #'s.
I bought a "better" test kit from the pool store. I tested it when I got home. Everything was pretty much the same except cya. It said to mix water & solution, pour in tube with black dot in bottom until I couldn't see the black dot. So, by doing this, I got between 80-100??
Anyway, I hope this will help figure it out.
I added 5 gallons of bleach when I got home.
Just for info: I have been buying the generic bleach from Wal-mart for .99 a gallon 6%. Today when I bought more, it is $1.27 gallon. Do you think they may be catching on???![]()
Thanks in advance!!
Oh, btw, pool is almost more blue than green cloud now!!
The way I see it, you have nothing to “gain” by helping me, just doing it out of the goodness of your hearts. So, I trust your judgement. And, your judgement saves me mega bucks. Or atleast it will when my water gets clear. Oh, I forgot, she also, told me that my "conversion" is complete. How can that be if my baq shock is still 51? & why is it still 51 after all the cl i have dumped in there?
