Thread: What to use for patching a chlorinated rubber/gunite pool?
Threaded View
  1. #2
    Default Re: What to use for patching a chlorinated rubber/gunite pool?
    If you want to REMOVE the paint, the only thing I've found is these: http://www.aurand.net/aurandweb/site/electric_tools.php
    You can't 'grind' it if off -- it just gums up the abrasive. And, you can't brush it off, because it's resilient enough to resist the bristles.
    As far as recoating info, I'd recommend reading the guides at Kelley Technical: http://www.kelleytech.com/olympic/ol...-bulletins.asp
    Regarding cracks and holes:
    + Holes are easy -- fill them with epoxy or concrete or whatever.
    + Cracks are hard -- usually they move, as temps change, and it doesn't take much movement to break anything rigid. There are expansion joint materials that work, but they are expensive, require very careful surface prep, and on larger cracks must be supported with foam backer rod or something of the kind.
    I'd say go for a contractor . . . but a lot of contractors can't do this sort of stuff. Still you might want to try.
    It really sounds like you may need an extensive rehab of your pool's surface, but I can't tell from here.
    Ben
  1. chlorinated shock from pool store BAD?
    By hudson169 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-01-2012, 11:40 PM
  2. Chlorinated Rubber
    By jac1020 in forum In-Ground Pool Construction and Repair
    Last Post: 06-21-2011, 09:29 AM
  3. Pool Pilot Rubber Washers Cracking
    By smallpooldad in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 07-08-2008, 11:46 PM
  4. AG Mat for Pool Steps - Will a 1 inch rubber mat work?
    By brianbo in forum Above-Ground Pool Construction & Repair
    Last Post: 06-09-2008, 11:58 PM
  5. Over Chlorinated Pool to 40 ppm by accident
    By smallpooldad in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-29-2006, 11:18 PM
