Results 1 to 10 of 25
Thread: Baquacil to Chlorine - something wrong
    Default Re: Baquacil to Chlorine - something wrong
    marie,
    thanks for the info. I will do that. Once the chlorine level gets that high, how long does it take to burn it off to a normal level for swimming? I am assuming that at those levels you cannot be in the water.
    mbar's Avatar
    Ashland, PA
    Once it holds the chlorine overnight, and you have no combined chlorine you can stop adding more, it won't take long to get back to normal levels. It is safe to swim at chlorine levels that high - you may notice your skin may be a little dryer, and you may want to wear an old swim suit, but the level of chlorine is not dangerous to swim in.
    Northeast PA
    b2001 is offline Registered+ Thread Analyst b2001 0
    Dallas, Tx
    Your question:
    How will I know all of the baquacil is out?
    and your previous statement:
    i backwashed the sand filter and it was dark orange when it came out.
    I had to continuously - 2 to 3 times a day - wash my cartridge filter and skimmer basket sock for about 2 or so days after my water cleared and I has holding the chlorine level overnight for my conversion. They both were still getting dark orange from baquacil. So it took a little longer for the residual baquacil to clear out. They both have cleared up nicely now - so give it a couple of more days for it to get filtered out unless your backwash is looking nice and clear now ...
    Hey All,
    Thanks so much for your help. It looks like all of the baquacil is out. I added 4 more gallons of 6% bleach this morning. When I got home from work the pool was crystal clear and clean. I backwashed and it was just about crystal clear also. Here are my current numbers.
    CL - 8
    FC-8
    CC- 0
    PH 7.0
    Alk 150
    Cal Hardness 70
    CYA - 40
    What now?
    Am I finished loading up with bleach? Do I let the CL levels settle before working on raising the PH?
    Thanks for any help.
    mbar's Avatar
    Ashland, PA
    You should still add bleach, because you used up 4 gal of bleach in one day, right? Yesterday you had cl at 7, this morining you added 4 gal of bleach, and now you have cl at 8. Keep adding bleach, your water is beautiful and you want to keep it that way. Take a cl reading at night after the sun goes down, then early in the morning. You can stop adding bleach when the numbers are the same, in other words you are holding the chlorine. You can add 2 cups of borax, and wait at least 2 hours and test again. Bring your ph up to 7.2. You should be proud of yourself - you did it!! All of your other numbers are good. Your alk is a little high, but ok, and if you have any cal hypo shock you could use that to bring up your chlorine because your calcium is low - They say you don't need calcium in a fiberglass pool, but I like to keep mine around 125 because I have a heater, and some other things I've read abuot fiberglass pools.
    Northeast PA
