Results 1 to 10 of 26
Thread: Just Set Up Pool...Need some pointers
    Default Re: Is my water safe to swim in?
    Quote Originally Posted by JSMANNING0001 View Post
    I did buy 1" chlorinating tabs. It says kills bacteria and controls algae... Janet told me to get Tri-chlor tabs... I found those tabs and got them because it says trichloro-s-triazinetrione 99.%..... Is this right?
    Yes, those are trichlor tabs. You'll do better to put them in a floater, because if you hang them from a sock next to your liner, you're going to get fading of the liner from the acidity of the tabs. Also, I would remove them from the pool while swimming so that you don't accidentally swim into a pocket of concentrated trichlor, which would be very uncomfortable, and possibly damaging, to your eyes.
    You did a good thing by testing your pH and adding acid accordingly, not just blindly following the pool store's advice. That's what we're trying to teach people here to do. Good job!
    I agree with Carl, though--get some chlorine of some type into that pool ASAP before you end up with an algae bloom!!
    May 2011
    DeFuniak Springs, FL
    Well, I got the tri-chlor tabs but were too chicken to use them, afraid I would mess something up... I did go back after researching online to find what i was looking for the...the purple label of stabilizer that was way over my reach so I didn't see it.
    I added about 33 oz by measuring cup since i couldn't do the 32 oz by weight. I hung it in a stocking off the return last night and well, playing with it today i noticed it dissolved easily so I played with it for about 10 min and got it all dissolved and was being shot across the pool by the water from the return. I added 40 oz of bleach and we will see how it does tomorrow. I can't check the levels at 4am when I got to work but I can check around 6 pm. To niece she could not swim as I didn't know what the water would be like tomorrow and could not test the bleach. I will test EVERYTHING tomorrow. Since the cya is all dissolved will it be safe to check it tomorrow or wait a few more days....?
    Sorry for not waiting for yall's answers.... I went with Janet's original help which I planned on from the git-go but couldn't find what i was needing... I found it and did it! Hopefully things will get better.
    Also, pump has been running for over 24 hrs and I titled the return up to bubble the water this evenign...guess i need to keep it going 24/7 till eveything evens out?
    Now, as long as my arm don't fall off tonight from having it in the HIGHLY concentrated, cloudy levels of cya being dissolved around my arm, then hopefully I will be back on here tomorrow evening with some test results!
    Thank you all....
    Apr 2011
    virginia
    sounds like you're on the right track. I would wait a few days to test the CYA, as it often doesn't show on the test for up to a week. work to maintain your pH and Cl for now, and post the full set of numbers and we'll let you know if you need anything else! Good luck- tell your niece she should be swimming real soon!
    If your CYA is completely dissolved, and the pump has been running all night, then it's okay to go ahead and test your CYA. You'll need to have an idea of how high it is so you can adjust your chlorine levels accordingly. We do tell people sometimes it takes up to a week for it to register, but that's when it's added via skimmer and takes a week or so in the filter to dissolve and show up in the water. If yours was dissolved directly into the water, then you should be able to get an accurate level by later today.
    May 2011
    WOO HOO! Seems like everything is on a rolll....for the good... at least till the storms hit to night and it gets yucky rain water...anyways here are my readings...
    FC 2
    TC 1.5
    pH 7.4
    TA 70
    CH 110
    CYA 45 (in between 45-50. Not sure if the dot was supposed to be fully disappeared. It started getting invisible around 50 but could still faintly see it. Not sure how if it literally had to be gone..... if so it was 45)
    I HAVE NOT ADDED CHLORINE since last night!!! WOO HOO! While it's not the greatest levels, it did stick. I would usually go out at lunch time and my reading would be clear...absolutely nothing! Do I need to add anymore? Anything I should do for this storm coming?
    Now, what should I do about my TA? I would say baking soda but my pH is right on target. my TA has been running about 120-125 until...I am guess, I added the stabilizer...it dropped since then.
    Does the low CH pretty mush refer to hard water just like in a bath? If so that might explain the weird feeling like hard water we were getting yesterday in the shower after getting out. It was a sticky/non slip feeling on my skin and when I touched my hubby and the baby in the pool.... how do I soften my water?
    Thanks and I look forward to the feed back! THANK you guys so much for the help... I was a little terrified of the CYA thing as I was afraid I would go over or not enough though my main concern was going over....
    Yes, you need to chlorine. With a CYA of 45, you need to keep the cl between 3-6 all the time. Since you have dipped below that and also since you have 0.5 CC, I'd suggest shocking the pool again. Since you just added the CYA yesterday, I'd still wait until about Sunday or so and then retest for it again to make sure you have the final reading on how much is in there.
    You can use a little baking soda to bump your alk up just a bit. Baking soda won't cause a big jump in your pH and even if it does come up just a little, that will still be fine. Add about a half a pound at a time and then retest after it has circulated for at least several hours. See how much it increases and then you can decide whether you need to add a little more. Aim for between 80-110 or so. Your calcium hardness reading is just fine.
    May 2011
    Thanks... I am new to this whole thing so can you explain shocking... I have 1 1/2 Big bottles of Clorox and a bag of POOLIFE Turbo Shock treatment. it says 78% available chlorine with 22% other ingredients. Says a minimum available chlorine of 75%.
    It's about a 3lb bag but doesn't say. Will the calulator tell me how much to add? What would this be called? How often/ when should I shock. The bag suggest once a week but I'm not sure...(Obviously follow instructions but since the company has a lot to gain by every pool in the world shocking once a week I am wondering if that is necessary...)
    Can you please tell me what merits a shocking? Is it something that I should do regularly or under certain situations...
    Sorry for so many questions just not sure. Also the bags says I shouldn't shock unless the CH is 220 ppm or more!?!?!
    Do I broadcast the granules in the pool as instructed? Just want to make sure it won't hurt the floor....
