Results 1 to 10 of 15
Thread: Start-up with chorine after 2yrs of Baqua-yuck
    Default Re: Start-up with chorine after 2yrs of Baqua-yuck
    Doesn't the bag of cal-hypo tell you how much so much quantity should raise the cl per amount of volume. i don't use cal-hypo, so not sure. Al (Poconos) uses cal-hypo and he says that his guess is that it easily would give you that much of an increase. That is a pretty hefty dose
    May 2011
    Central Illinois
    Taylor Kit K2006 arrived last night. Did my first test this morning with the following readings...
    FC - 4.5
    CC - 0
    PH - 7.0
    TA - 120
    CYA - Not registering
    Couple things... 1) I'm guessing my pH is low because of rainwater in the pool this week, and a possible overreaction on my part to last week's high pH. I added a gallon of MA over the course of two days. Probably not necessary. So I'm off to Wal-Mart to get some 20 Mule Team. 2) I only added the CYA on Tuesday, so maybe that's why it isn't showing up. But I put 4lbs of stabilizer in the skimmer S-L-O-W-L-Y. Would it be dissolved and ready to register by now?
    Thanks for all the help folks. I will say the water has never been clearer in this pool, since the switch from Baquacil. Really enjoying the independence from my pool store.
    Your numbers look good especially when you add a little Borax to bump the pH up a bit. Give it a few more days before checking the CYA reading so you don't waste the reagent. It can take up to a week to totally dissolve.
    May 2010
    Central NJ
    I can't imagine you added enough copper to turn things green that quickly with dual action pucks. From your post it seems like you only used a few. More worrisome is using pucks in your skimmers, I know folks who have caused real hardware problems from "burning out" skimmers. I use Cal-Hypo (73%) to shock on opening. 15 pounds. Gets me to 50ppm. I keep CYA between 60 and 75. I open early (colder) and just don't think about anyone getting in the pool for 10 days at least. I find this the easiest and my CH always stays just fine, I use BBB completely otherwise. I think of shocking just like Z Pack. The nuclear option. I close with 25+ ppm and that CYA, figuring on keeping Cl until the temps drop. My pool has never been better since finding the Pool Forum.
    33,000ish gallon, 20X40 IG Vinyl Liner, no heater. Full sun, Sand filter. Been pool stored more times than I can count, not anymore! Thanks PF!
    20'x40' rectangle 33K gal IG pool; Bleach; Hayward sand filter; AO Smith 1HP pump; 14hrs; Taylor K2006; utility water; summer: ; winter: ; iPhone; PF:3.6
    Quote Originally Posted by PBLsQuad450 View Post
    That's what we like to hear! Good to see you back on the forum for another season.
    May 2010
    Central NJ
    Glad to be back. Question on that though, I don't see references to joining or anything anymore? I would like to re-subscribe/support PF. Been here a year, and this years start up has cost so little, I promised to share last year so..
    May 2011
    Central Illinois
    Here are test numbers from this morning (Thursday):
    FC - 6.5
    CC - .5
    pH - 7.6
    TA - 130
    CYA - 0
    After a week I still don't have stabilizer registering. I finally had to do a backwash last night, because circulation had slowed down. Heavy load of swimmers and sun over the holiday weekend. To the point where I couldn't get the FC to register on Tuesday evening. Shocked with 5lbs of cal hypo (49%) Tuesday evening. Another heavy load of swimmers Wednesday (kids are out of school), so I shocked again Wednesday night, this time with six 3/4 gallon jugs of 6% (s'what the wife brought home from Target). I'm guessing I need to pick up another bottle of stabilizer and see if I can get it dialed in. Today is cloudy, so I may have a day without swimmers, to get the chemistry right.
