Algae or Sediment?
Filled my pool last night added some bleach...etc. This morning about 8 hours after it was filled there are brown spots on the bottom. When I get close to them with the net they dissolve. However, they are back and start building back up with in an hour. It's only on the bottom in small spots or near the seam or the few creases my husband left.
Could this be an algae so quick? With in hours? or is it most likely the stuff in my city tap water? It's almost a rust color. Not slimy and very thin but layers up.
What should I do? Still trying to get chlorine levels up...
Also, when i filled the pool with the hose the water had a slight brown/brackish color to it...now it's nice and clear...could this just be the stuff that was in the water? if so how do i get it out...if not how do I treat it?
