Results 1 to 10 of 16
Thread: Pump and filter set up, what else do I need? New Pool Owner - 33' AG
    May 2011
    South Arkansas
    Default Pump and filter set up, what else do I need? New Pool Owner - 33' AG
    Wish I would have had enough fore thought to look for this site sooner. Just went through a nightmare in purchasing a 33' AG. After 6 no shows from the installers in 8 weeks time, we finally got our pool installed. Now I have questions because I don't trust the company that originally sold the pool to us. I say originally because after all of the no shows and a BBB complaint, we recieved a full refund AND the pool.
    Pool size is 33' round, 54" deep.
    Pump size: 1.5 hp GE pump
    Filter: AquaView~AS 20" Sand Filter / 2 sqft / Mas Pres 25psi / 150 lbs sand
    Question: The pump filter set up is flex pipe and I would like to replace with hard pipe eventually. For now though, what else should I consider adding. Bypass falve, flow rate meter, in line chlorinator (pool came with a floater).
    Also, how often should i run my filter?
    I apologize if some of the questions seem remedial but the dealer is of no assistance and, of course, no manuals or instructions of any kind came with the pool.......other than these nifty "No Diving" stickers.
    Thanks in advance, and I look forward to learning a lot about the pool world.
    Default Re: Pump and filter set up, what else do I need? New Pool Owner - 33' AG
    Welcome to the Pool Forum! I'll let one of our equipment gurus help you with your plumbing questions. A few questions for you:
    -- Do you have a good test kit? If not, you need one. Click on the Amazon link in my signature line below and get yourself a Taylor K-2006 or 2006C.
    -- Is the pool filled yet? If so, was it filled from municipal water, well or ???
    -- if it is filled, what all have you added to the pool thus far?
    Probably a good idea to post a complete set of water testing results for someone here to take a look at. Also, go to our sister website www.poolsolutions.com and do a bunch of reading. Lots of good info there. Also, read through many of the posts on the Pool Forum. The more you read, the more questions that will probably be generated. Come back and ask away and also give us the info requested above.
    Glad you found us and hope you enjoy the forum!
    May 2011
    South Arkansas
    Thanks for the reply. Pool's not full yet, probably wont be full until Friday afternoon since I'm filling it from a garden hose. I do need a good test kit, thanks. What's the difference between the 2006 and the 2006C.
    Apr 2011
    virginia
    my 33 ft AG I try to run the filter on high about an hour (good mix of water before testing, and skimmer works better on high) then run on low overnight- about every other night. I'm not religious about a schedule as long as water stays clear and tests good; sometimes forget the pump for a day, sometimes leave on 1-2 days!
    I'm guessing at the specs, but I think your filter's too small for your pump...or your pump's too big for your filter.
    Assuming your pump's uprated (normal for AG pools) it's ballparking here, about the equivalent of a 1hp full-rated pump (normal for IG pools). And, a 1hp full-rated pump, like a Hayward Superpump, needs a 200# sand filter. One of our mods, Poconos (Al) goes for a 300# sand filter. That's because if you go over the filter's capacity, you have problems, but the performance improves the less of the capacity you use. So I run my pump on low speed and long ago noticed that my water gets clearer that way.
    I'll let the pump pros confirm, deny, or refine my assessment.
    BTW, what type of flexible plumbing do you have? If installed correctly, there's no reason to replace it. I use a combination of 1.5" hard PVC and 1.5" TigerFlex, which is flexible PVC that uses glued-on fittings just like the hard stuff. Al, at key points, actually uses automotive radiator hose, without any problem.
