Re: Pump and filter set up, what else do I need? New Pool Owner - 33' AG
I'd add MA to drop pH to 7.5, then add chlorine (like Aylad said, initially you can use trichlor or dichlor to get CYA also)
Other than immediately after adding chems, I've always been in the pool as soon as water was in! when you're filling with fresh water, it's as safe as drinking the water from the hose!
