Results 1 to 10 of 35
Thread: Pool Still green after 20 gals of bleach...1st time post.
    May 2011
    SouthEast Virginia
    Default Re: Pool Still green after 20 gals of bleach...1st time post.
    Madwil...In surry county,work in Williamsburg.
    Apr 2011
    virginia
    Cool- my pool was 86 yesterday evening; got home from work with a cold beer and a swim!
    Good luck on your pool clearing up for Memorial Weekend!; I'll be using the big salt water pool to our east this weekend! camping at FT Story, going to the beach...
    May 2011
    SouthEast Virginia
    Wife went to pool store. They could not figure out what was wrong with our water other than our phospates are extremely high,no other recs on pool chemicals. Asked her what color and she said it was green,they said we don't know what to tell you other than add phosphate balls in the skimmer. She bought 2 at $10.00 and I told her No we are not using them....shes know more chemistry than me and is mad at me now . Pool store said do not use bleach it will hurt your liner.
    Anyway pool is still a mid to light green,not slimy or smelly does smell like chlorine. Total chlor off the chart,free chlorine pegged,alky ,ph ,cal all ok ph actually came up to middle of color chart after borax yesterday evening.
    Our real test kit is still not here....dang it!!! maybe tommorrow.
    May 2011
    SouthEast Virginia
    Ok kit is in test results from the wifes test
    FC 39.5ppm
    combine 1.5 ppm
    ph 7.2
    alk 125ppm
    cya>100ppm
    guess the cya is the issue pool is green still
    Drain and refill time?
    May 2011
    SouthEast Virginia
    Well I am on well water and I have a deep well that is only 20yrs old. I imagine there's plenty of water left in that well. I am going to vaccum it in the am to waste and then leave the vaccum in the pool sucking from the bottom and drain a good bit off. I have not decided how much but not anymore than 1/2 is my guess. probaly take a sunday and monday to refill.
    Wells used to be rated at gallons per minute, with 20+ as the max rating. I don't know if that's still true. Of course, the well gets ground water deep down.
