Thread: DE Filter issues.....
    fog80 is offline Registered+ Thread Analyst fog80 0
    Columbia, Maryland, USA.
    Default Re: DE Filter issues.....
    Hi Waste,
    I have a backwash line connected to my filter, but when i backwash it does dump out my DE. I broke down the unit yesterday and gave it a soak in dishwashing detergent and then muriatic acid. I've never seen the fingers this clean!
    Now my starting pressure is 5.......the lowest i could ever get it before cleaning was 12. I noticed that three of my "fingers" lost their fabric covering and were just exposed plastic....so I've ordered 10 new fingers and a new bottom plate (which had some cracks near the main shaft in the middle). I'll be installing them this weekend.
    I put in 3 gallons of 12.5% chlorine yesterday and ran the filter all night. This morning my pressure was up to 20 but after a bump, it went back down to 5. Also, the pump didnt seem to lose prime even though the pressure went up so high.....didnt know a good cleaning would affect that.
    I'm going to keep on shocking and filtering and then vacuum to waste when I can see the bottom. Hopefully it will be clean soon.
    FYI, i changed out all my bad "fingers"....over 20 of them. I also changed out the diaphram gasket on the DE filter. Over the next 48 hours my pool cleaned up to the point where I could see the bottom. From there I scooped out as many leaves and pine needles as i could and vacuumed up the rest.
    Water is crystal clear now and my DE filter pressure is holding steady at 10psi. Thanks everyone!
