Results 1 to 10 of 13
Thread: How much CYA in trichlor tablets?
    May 2011
    Coral Springs, FL (SE Florida - near Fort Lauderdale)
    Default Re: How much CYA in trichlor tablets?
    aylad - I am in SE Florida and also have a pool in the sun all day. I plan on using your method of high CYA. What do you keep your chlorine level at and is there a downside to keeping it lower with a high CYA? Do swimmers find it uncomfortable?
    Thanks!
    My pool:
    15x30 inground concrete pool w/spa in one corner overflowing into pool, all under screen enclosure
    Hayward C1200 StarClear Plus Cartridge Filter
    Jandy Laars LX400 propane heater w/120 gal above-ground tank
    Jandy AquaLink RS OneTouch controller w/PDA remotes and computer control
    JVAs control pool/spa switch and also allow drain opening
    Hayward Navigator
    I'm not sure what chlorine level aylad runs but as far as your question about any down side to lower chlorine with high cya --- yes, ALGAE! Higher chlorine with higher cya is no more uncomfortable for swimmers than lower cya and lower chlorine. Take a look at the 'Best Guess' table in the link in my signature. It shows you the correlation between chlorine and cya levels.
    May 2010
    Central NJ
    I was in exactly the same position when I found this forum. I found the partial drains to be a real pain. My chlorinator is just hanging out in case I decide to add CYA with Trichlor. You will jump right back up faster than you think, especially if you have a heat wave and those pucks turn chalky and vanish. You will have an algae bloom as well. And no decent way to deal with it because the high CYA and high enough Cl to shock will take forever to come down. Who wants the work of taking care of a pool you cant swim in? The pool just becomes unmanageable in my opinion. Sure, I have control issues. BBB satisfies them completely!
    33,000ish gallon, 20X40 IG Vinyl Liner, no heater. Full sun, Sand filter. Been pool stored more times than I can count, not anymore! Thanks PF!
    20'x40' rectangle 33K gal IG pool; Bleach; Hayward sand filter; AO Smith 1HP pump; 14hrs; Taylor K2006; utility water; summer: ; winter: ; iPhone; PF:3.6
    There are other ways to deal with high CYA pools, but they involve extra expense using algaecides and other products. If one absolutely cannot (or is unwilling to) dilute the water or maintain a higher FC relative to the CYA level, then one can use PolyQuat 60 weekly both to control algae and as a mild clarifier (which you need because the lower active chlorine level breaks down organics more slowly). It still won't prevent algae if the chlorine gets to zero, but the FC level doesn't have to be as high as it otherwise would. Of course, this is extra cost -- usually around $2-4 weekly (after a larger initial dose) depending on the size of the pool.
    I know that in my own pool years ago (before visiting this forum) when I was initially using Trichlor pucks/tabs I was also using algaecide, but every other week. My pool "turned" somewhere around 3 ppm FC with 150 ppm CYA. If I had been using the algaecide weekly then perhaps I could have gone to around 200-250 ppm CYA again with 3 ppm FC. So very roughly speaking, the algaecide may lower the minimum FC level from the 5-7.5% of CYA range to the 1-2% range, but that's really pushing it. You still have the problem that IF your pool gets behind the algae curve, then it still takes a very high level of chlorine to get rid of the algae since shocking the pool will tend to get rid of the algaecide more quickly so you're relying on the chlorine to get rid of the algae.
    Yet another option is the use of 50 ppm Borates, but we don't have enough data to know how much it prevents algae growth. We know that it does as we've had multiple reports about that and I have it in my own pool now and have done some experiments, but my hunch is that it's not better than PolyQuat, but not that much worse either -- so a total guess on my part is that it would allow for something in the 3-4% FC as a proportion of CYA range, but I don't know exactly where in that range.
    There are other options, but they have side effects or are not always effective. Copper-based algaecides kill algae, but can stain pool surfaces. Phosphate removers take the edge off of algae growth, but don't help if there are organic phosphates in the water, especially if the chlorine gets to zero at which point bacteria can quickly convert organic phosphates into orthophosphate.
    Quote Originally Posted by HofstraJet View Post
    Thanks!
    I keep my chlorine level between 8-10 at all times. I also shock it after a couple of days of heavy rains, especially if they're hurricane-driven, and at the end of a week of heavy bather load (my house is the place where all the kids on the street hang out all summer).
    I use the best guess chart (link in mine and Watermom's sig) just like we recommend to everybody else. Letting your chlorine get below 5 or 6 with high CYA will result in an algae bloom, and it takes a LOT of bleach once that happens to get it up to shock level, but if you never let it get below 6 to begin with, it's not a problem.
    As for comfort, like Watermom said, higher chlorine with higher CYA feels exactly the same as lower chlorine with lower CYA. Any discomfort is usually caused by letting your pH get out of whack, or letting CC build up without a shock.
    May 2011
    Thanks, everyone, for your thoughts. I am adding 50 ppm borates to the pool this weekend and will keep a close eye on things when I start using trichlor tabs next week. My goal is to minimize the amount of active maintenance my pool needs. Pool guy used to come once a week and add liquid chlorine best I can tell, but now that I know what is involved, I see things were certainly out of whack for part of the week as it doesn't really seem possible to maintain a pool with once-a-week maintenance.
    My pool:
    Hayward Navigator
    You are right, once a week maintenance isn't going to work for your pool chemistry but 5 minutes every day or two will!
  1. Unstabilized tablets
    By psandro in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-10-2011, 01:48 PM
  2. HTH Tablets with NO CYA
    By mswlogo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-30-2007, 07:51 AM
  3. Tablets or Granules?
    By bob57 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-31-2006, 09:44 AM
  4. CYA tablets
    By karenkr in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-14-2006, 09:39 AM
  5. Do 3" tablets go bad?
    By rayh78 in forum Pool Equipment & Operations
    Last Post: 06-17-2006, 10:20 PM
