return inlet help
I purchased a Poolskim, and it connects to the return inlet. Two problems, in the instructions for installation, they show the return inlet unscrewing, mine has a face plate, which I was able to pry off. The Poolskim screws into the return inlet. Well I do not have threads to attach. There are threads inside that seem to be about an inch in diameter, so I am trying to find pvc fittings that may make this work. The bigger problem, is that I do not feel anything from either return inlet. Is there not suppose to be some pressure there? I do have valves on my pump that say return, but they are frozen. Please advise, pvc fittings and return pressure.
- You may not post replies
- You may not edit your posts
Forum Rules
