Thread: Im losing water
    Cleveland, OH
    Default Im losing water
    I opened my pool yesterday. It held the water over the winter. I drained it just below the return. I filled it up and over night it drained back down to just below the skimmer. I am thinking i have a leak in the skimmer.
    THe gasket for the widemouth faceplate has been replace 2 years ago when i replaced the liner. I am wondering if maybe the other gasket is bad. It looks old and dry rotted. I was going to take it apart but couldnt get it apart. If that is the problem do i need to replace the whole skimmer?
    I was thinking so. I posted in another post asking for a good skimmer to get because I may just go that route anyway.
    What do you guys think?
    Default Re: Im losing water
    Have you tried dye testing the skimmer? Before replacing the skimmer, I'd make sure that it is the problem.
  1. losing a lot of water this year
    By jilted in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-28-2012, 11:49 PM
  2. losing water after replaster
    By pool_slave in forum In-Ground Pool Construction and Repair
    Last Post: 01-17-2012, 04:26 PM
  3. losing water
    By bcpoolowner in forum Above-Ground Pool Construction & Repair
    Last Post: 06-25-2007, 11:43 AM
  4. Losing Water!
    By scooter hotrod in forum In-Ground Pool Construction and Repair
    Last Post: 08-25-2006, 10:18 AM
