Results 1 to 9 of 9
Thread: Pressure gauge failure?
    May 2011
    Default Re: Pressure gauge failure?
    I have lots of trees and this time of year lots of tree stuff in the pool. Water is clear and the inlet flow does indeed seem strong. I'll wait another week to see if I have psi increase. Thanks
    Apr 2011
    virginia
    check the gauge with the pump off- if it returns to 0, then 21 when you turn pump on, it's probably ok...
    if it stays at 21, its stuck and go ahead and replace...
    May 2011
    A few days ago I did that: turned the pump off it still said 21. I tapped it and it went to zero. Then pump back on and it went to 21.
    However, today it reads 24, soooo I think it just may be ok? Water still crystal clear.
    Thanks again everyone
    Apr 2011
    virginia
    if it still hangs when you turn pump off, I'd replace it; about $10 at Home Depot, 5 minutes to replace
    May 2011
    That inexpensive, I will do it. Thanks
