Results 1 to 8 of 8
Thread: Do I need DE?
    N.E. TX
    Default Re: Do I need DE?
    I measured the CL with a "drop based" test from WalMart. It's the one where it turns yellow. It only measures to 5ppm so I diluted with three parts water and still got 5 which told me it's at least 20ppm. According to the "black dot" test for cya - it should be around 90, but the pool store told me last week that it was 42 and I've only added 3lbs since. So I am really chasing my tail here. I will keep the CL up, but it only checks for TC. Does anyone know if there is still a pretty good waiting list on Ben's kits? Thanks for the replies and please keep em coming. It's very encouraging (right now I need that).
    Thanks again,
    Brad
    duraleigh Guest
    Hi, Brad,
    I'll repeat three words in my post...."KEEP IT THERE". If your Cl was 20 last night, it won't be this morning.
    I think you're on the right track but it is imperative you keep bringing your Cl back up to 20 or so every chance you can.....three times each day is not too much.
    Your water will sparkle shortly.
