Welcome to the Forum!
Despite your claim that there is good drainage around the pool, unfortunately, it seems obvious from your description that there IS a drainage issue. (I know this isn't your fault!)
It sounds like water is running under the shallow end [my reasoning- the shallow end floats (causing the wrinkles) and it takes more than 3 years for a small stream of water to wash the cement out of vermiculite, leaving it 'mushy' or simply washed out)]
You said- how high is your lot, compared to the surrounding lots?as the pool is pretty high on my lot and the drainage is good all the way around it.
BTW - even a crease (wrinkle) in a 2 year old liner should come out (as long as the liner wasn't severely chemically abused).
Where are you located?
I'll try my best to help you with this![]()
