Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Free chlorine is non existent
    May 2011
    Default Free chlorine is non existent
    Ph and alk are now good. CYA is at the low end. Hardness is a bit high.
    I have dumped in a total of 27 Bags of shock in the past week. 8 bags last night. This morning free chlorine still does not register. Water has been tested at the pool store twice in the past week. I have bumped up the alk and ph as a result.
    Help!!
    Thank you.
    Default Re: Free chlorine is non existent
    Can you post your complete test results?
    Also, can you tells us (1) what your approximate CYA level was last fall, and (2) what your water LOOKS like right now?
    Ben
    Hi and welcome. Mdpools as in you're a doctor who has a pool?
    Let's start at the beginning.
    We'll need some info. Try to get us what you can.
    We need the actual tests and the values measured. We vary as to what "good" means. Tests should include:
    Free Chlorine (FC)
    Combined Chloramines (CC)
    Total Chlorine (TC)
    pH
    Total Alkalinity (TA, T/A, Alk)
    CYA (Cyanuric Acid, Stabilizer, Conditioner)
    Calcium Hardness (Total Hardness, CH, TH)
    What kind of pool do you have?
    What is the volume (in gallons)? If you don't know and can estimate the cubic footage, multiply that number by 7.48 to get gallons.
    What kind of pump and filter do you have? What size of each?
    Also what is in the chemicals you are using. "Shock" is actually a verb. There is no substance called "shock". It could be Di-Chlor powder, Cal-Hypo Powder, Tri-chlor powder, or Lithium Hypochlorite powder.
    What are you testing with? If you are using DPD chlorine test kit, high chlorine can bleach out the test and make it look like you have no chlorine when you have lots of it. the cheapie OTO tests just go from yellow to orange to brown--no bleaching.
    So get us what you can and we can give an opinion of what's going on and what we think you should do.
    May 2011
    Thanks for the posts. User name means I live in MD and have a pool. Not very original, I know.
    Pool is in ground. 30k gallons. DE filter.
    Ok results from test 1.
    CYA is 10
    Tot chlorine is 3.1
    Free chlorine is 0.8
    ph is 6.9
    Alk is 87
    Hardness is 265
    That is all they listed.
    Put in 16 lbs of Balance pak 100 to bring up alk
    Put in 2 lbs of ph up
    Put in 6 lbs of CYA
    Put in 15 bags of burn out extreme (calcium hypochlorite)
    38 oz of algaecide
    Do not have CYA from last fall. Pool water is crystal clear.
    5 days later.
    Sat index is minus 0.7 no change from previous
    TDS is 1700 (was 1600)
    Tot chlorine is 1
    Free chlorine is 0
    Ph is 7
    Alk is 78 (went down)
    Hardness is 246
    Put in 22 lbs of alk up (balance pak 100)
    1 lb of ph up
    8 bags of calcium hypo (granular shock)
    Using test strips. Showing no free chlorine.
    [ combined multiple posts - moderator ]
    Ok, that's enough for a start.
    #1 - Stop trusting your dealer (BioGuard?); stop worrying about alkalinity or pool "balance", at least for now.
    #2 - ignore your TDS results.
    #3 - get a cheap OTO / phenol red test kit (Walmart, whatever)
    #4 - get 20 gallons of plain 6% household bleach; start adding them 5 gallons at a time IN THE EVENING within 2 hours of sunset.
    #5 - use your OTO kit to test 1 hour after adding bleach, and again in the AM, but no more than 2 hours after sunrise.
    #6 - report results here.
    #7 - keep your pH between 7 and 7.8, but do not use any other chemicals.
    #8 - if it can fit your budget, get a K2006 or 2006C kit for future testing (Amazon links below)
    Ben
    I have good news and bad news for you.
    1) The good news is you can replace pH Up and Balance Pak 100 cheaply.
    2) The bad news is pH Up is EXACTLY the same chemical as Arm&Hammer Washing Soda (in the yellow box) for $.80lb and Balance Pak 100 is EXACTLY the same chemical as Arm&Hammer Baking Soda in the orange box, also about $.80/lb. And both are in your supermarket.
    3) More good news: Ben is always right, unless we disagree, in which case I'm right (JUST KIDDING, BEN!) You can't go wrong following his advice. Ben left out that to raise your pH, which he told you to do, you should use Borax (20 Mule Team Borax). Borax is usually right next to washing soda in the supermarket. If Ben wants you to raise pH by alternate means he'll update this.
    May 2011
    Having a hard time replying to thread from iPad. Anyway I completed steps 1-5. The first reading after the initial 5 gallons of bleach was 7.2 ph and 1.5 chlorine. I will update this thread as things progress. Thank you guys.
    Sounds good. -ben
    May 2011
    Night 2. Five more gallons of bleach. Reading 1 hour later are ph 7.2 and chlorine 1.0.
    Next day chlorine is still very low. Will continue for 2 more days.
    Question, any idea what is eating up all the chlorine? Going back to the 20 plus bags I put in last week? Very curious about that. Thanks.
    Without stabilizer, you can lose 90% of the chlorine in your pool (regardless of how much is there) in 2 hours of full sun. There are lots of variables here -- how clear is your water, how "full" is the sun, how deep is the pool -- but you get the idea, I hope.
    Also, if you HAD stabilizer in your pool last year and didn't, when you opened this year, and did NOT drain your pool, you may be WORSE than unstabilized: you may have no stabilizer AND have ammonia left over which bacteria 'pooped' out after eating your stabilizer.
    Best way to check: add chlorine late in the day; test levels an hour later and then again in the morning within 2 hours of sunrise. If there's a big difference, you have some sort of goo in the pool that's using up your chlorine.
    In general: lose chlorine at night = goo; lose chlorine during day = many things but often, no/low stabilizer.
    Ben
  1. Can't get the free chlorine!
    By poolhelp in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-02-2012, 04:43 PM
  2. free chlorine?
    By DONNIE in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 12-23-2006, 01:42 AM
  3. Free chlorine
    By meade in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-23-2006, 10:46 AM
  4. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  5. need help with free chlorine
    By erk in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-27-2006, 11:46 PM
